MV-22 Osprey
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 8 settembre 2022, 16:36
Nuova avaria a un CV-22 Osprey dell'Air Force Special Operations Command ...
A CV-22 Osprey tiltrotor aircraft belonging to the U.S. Air Force is stranded at a Norwegian nature preserve after suffering a mechanical failure in flight, the head of Air Force Special Operations Command confirmed Wednesday.
The Osprey has sat among the ferns and salamanders of the High North since Aug. 12, when the tiltrotor system’s erratic clutch forced airmen to make an emergency landing at the Stongodden preserve on the island of Senja in Troms, Norway.
The area’s tricky terrain and weather now create a confounding rescue mission even for special ops airmen, who are trained to extract troops from remote locations around the world.
airforcetimes.comAir Force special ops Osprey stuck in Norway wilderness after mishap
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 9 settembre 2022, 0:13
Il comandante dell'AFSOC spiega perché ha ordinato la messa a terra dei CV-22 Osprey ...
Air Force Special Operations Command has known about the issue at the heart of the recent CV-22 Osprey safety stand down for years now, just as the Marine Corps and other stakeholders have.
But after two incidents in quick succession - including one that has left an aircraft stranded in a nature preserve in Norway - AFSOC commander Lt. Gen. James C. “Jim” Slife decided some action had to be taken to “draw attention” to the problem, even as the root cause remains a mystery, he said Sept. 7.
AFSOC first announced the grounding of the fleet Aug. 16, citing incidents of “hard clutch engagement.”
Such instances start with a “slipping sprag clutch inside the input wheels on the engines,” Slife said at an AFA Warfighters in Action event.
airandspaceforces.comAFSOC Commander Explains Why He Ordered CV-22 Osprey Stand Down
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 30 settembre 2022, 16:41
Il CV-22 Osprey dell'Air Force che aveva effettuato un atterraggio di emergenza sull'isola norvegese di Senja è stato finalmente rimosso ...
An aircraft built to quickly infiltrate and exfiltrate troops from far-flung locations left a Norwegian nature preserve Sept. 27, more than a month after it emergency-landed.
The CV-22 Osprey belonging to Air Force Special Operations Command (AFSOC) had been stranded on the island of Senja since making a controlled emergency landing Aug. 12.
The issue was a hard clutch engagement, which causes the tiltrotor aircraft to lurch suddenly and can damage the gearbox and engines.
The problem led AFSOC to stand down its fleet of around 50 CV-22s.
While the issue remains unsolved, the aircraft was cleared to fly again in early September.
Except for the one in Norway.
airandspaceforces.comMarooned Air Force CV-22 Osprey Finally Removed From Norwegian Island
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 27 agosto 2023, 11:22
Notizia in aggiornamento ... Un MV-22 Osprey che trasportava 20 Marines si è schiantato al largo delle coste dell'Australia ...
news.usni.orgMV-22 Osprey Carrying 20 Marines Crashes in Australia
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 4 settembre 2023, 1:21
Il Comandante del Corpo dei Marines ha ordinato, dopo alcuni incidenti mortali, una revisione della “cultura della sicurezza” ...
Il massimo leader del Corpo dei Marines ha ordinato, Martedì scorso, ad ogni unità dei Marines di rivedere il proprio approccio alla sicurezza, dopo che due velivoli si sono schiantati a pochi giorni di distanza l'uno dall'altro uccidendo quattro Marines in totale nonché un Marine morto durante l'addestramento al fuoco all'inizio del mese.
Il Comandante ad interim del Corpo dei Marines, Generale Eric Smith, ha ordinato alle unità di riunirsi a vari livelli – battaglione, squadrone, plotone e così via – per discutere la loro “cultura della sicurezza” entro il 15 Settembre prossimo.
marinecorpstimes.comTop Marine orders ‘culture of safety’ review after deadly crashes
Anche qui … news.usni.orgMarines Call for Safety Review After 5 Marines Die in August Training Accidents
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 2 dicembre 2023, 19:46
E, nel frattempo, ne è caduto un altro ...
news.usni.orgJapan Asks U.S. to Suspend Local V-22 Osprey Operations
airandspaceforces.com7 Airmen Still Missing, 1 Dead After Japan Osprey Crash
en.wikipedia.orgAccidents and incidents involving the V-22 Osprey
spiridione
Re: MV-22 Osprey
Messaggio da spiridione » 4 dicembre 2023, 9:34
Aereo controverso, tecnicamente oltre che concettualmente.
Magari sarebbe il caso di metterli a terra e fare qualche indagine approfondita, sia sul velivolo che sugli operatori.
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 4 dicembre 2023, 9:55
Penso tu abbia ragione e spero che alla Marina Militare, che, in passato, aveva espresso il suo interessamento verso tale velivolo, non venga in mente di acquistarlo ...
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 4 dicembre 2023, 17:12
Relitto dello schianto dell'Osprey ... sono stati ritrovati i resti di 5 aviatori ...
Dopo una ricerca durata quasi una settimana, le squadre di ricerca statunitensi e giapponesi hanno localizzato la maggior parte dei rottami del CV-22 Osprey dell'USAF precipitato al largo delle coste del Giappone Meridionale, insieme ai resti della maggior parte dei membri dell'equipaggio.
Le squadre di ricerca e soccorso stavano cercando il velivolo da quando si era schiantato il 29 Novembre.
I resti di cinque membri dell'equipaggio sono stati ritrovati il 4 Dicembre, ha dichiarato in un comunicato il Comando delle Operazioni Speciali dell'USAF, mentre i resti di un precedente membro erano stati recuperati il 2 Dicembre.
airandspaceforces.comOsprey Crash Wreckage, Remains of 5 Airmen Located
Le preoccupazioni del Governo Giapponese ...
news.usni.orgJapanese Officials Raise Concerns Over V-22 Osprey Flights
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 7 dicembre 2023, 9:11
spiridione
Re: MV-22 Osprey
Messaggio da spiridione » 7 dicembre 2023, 11:21
Tutti a terra !!!
news.usni.orgPentagon Grounds All V-22s for ‘Potential Materiel Failure’ After Crash off Japan
airandspaceforces.comAir Force, Navy, Marines Order V-22 Osprey Standdowns after Deadly Crash
Come volevasi dimostrare... :roll:
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 8 dicembre 2023, 11:10
Ulteriori informazioni ...
news.usni.orgUSS Carl Vinson Operations Ongoing Amidst V-22 Groundings, Navy Says
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 8 dicembre 2023, 17:33
Gli "Osprey" avevano una storia di problemi di sicurezza molto prima di essere messi a terra ...
Quando le Forze Armate statunitensi hanno compiuto, questa settimana, lo straordinario passo di mettere a terra l’intera flotta dei "V-22 Osprey", non stavano reagendo solo al recente incidente mortale avvenuto al largo delle coste del Giappone.
Il velivolo, nella sua breve storia, aveva già avuto una lunga lista di problemi.
militarytimes.comOspreys had history of safety issues long before they were grounded
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 16 dicembre 2023, 1:15
Operativi ... ma solo in caso di emergenza ...
news.usni.orgMarines in Med, Red Sea Can Fly MV-22s in Emergency as Osprey Groundings Continue
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 24 dicembre 2023, 15:16
Si investiga ...
airandspaceforces.comLawmakers Open Investigation into Osprey Safety after Deadly USAF Crash
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 11 gennaio 2024, 17:50
Un Organo di Vigilanza Federale indagherà sulla situazione di sicurezza degli Osprey a seguito dell'incidente avvenuto alla fine dello scorso anno
Un Organo di Vigilanza Federale esaminerà la storia della sicurezza della flotta dei V-22 Osprey delle Forze Armate degli Stati Uniti a seguito di un incidente che ha causato la morte di otto aviatori delle Operazioni Speciali al largo delle coste del Giappone alla fine dello scorso anno.
L'Amministratore Delegato per le relazioni con il Congresso del "Government Accountability Office", A. Nicole Clowers, ha confermato l'indagine in una lettera datata 19 Dicembre inviata in risposta a una richiesta presentata dai Rappresentanti Mike Waltz e John Garamendi, entrambi membri dell'House Armed Services Committee.
airforcetimes.comFederal watchdog to investigate Osprey’s safety record after crash
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 14 febbraio 2024, 16:57
L'USAF sta rivedendo il ruolo dei suoi CV-22 approfittando del periodo di messa a terra
L' Air Force Special Operations Command (AFSOC) sta rivedendo il ruolo della sua flotta di CV-22, concentrandosi sul fatto che sia organizzata ed attrezzata per operazioni sicure, nel mezzo di un fermo di tre mesi della stessa a seguito di un incidente mortale.
Il capo dell'AFSOC, Generale Tony Bauernfeind, ha affermato che tale revisione si aggiunge ad un rapporto privilegiato della Commissione Investigativa sulla Sicurezza e ad un rapporto della Commissione Investigativa Pubblica sugli Incidenti per determinare cosa abbia causato lo schianto in mare al largo delle coste del Giappone, il 29 Novembre 2023, di un convertiplano Bell-Boeing.
Nell'incidente hanno perso la vita tutti gli otto membri dell'equipaggio.
aviationweek.comU.S. Air Force Reviewing Role Of CV-22s Amid Grounding
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 18 febbraio 2024, 1:06
Ritorno al passato ...
L’incertezza sul ritorno in piena operatività del convertiplano V-22 sta spingendo la Marina USA a riconsiderare a breve termine i suoi piani su come portare i rifornimenti alla sua flotta di portaerei, ha affermato il comandante della Marina Militare americana.
La forza armata inizialmente prevedeva di ritirare i rimanenti 15 aerei C-2A Greyhound COD – Carrier Onboard Delivery nei prossimi due anni e di sostituirli con un totale di 38 convertiplani CMV-22B Osprey sviluppati e prodotti appositamente per questa attività.
Ma gli Osprey sono attualmente tutti fermi a terra a seguito dell’ultimo incidente mortale.
aviation-report.comLa Marina USA torna a puntare sugli iconici C-2A Greyhound mentre continua lo stop alle operazioni dei convertiplani V-22
Secondo news.usni.orgNavy Surging C-2A Greyhounds as V-22 Groundings Continue
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 25 febbraio 2024, 10:47
L'Air Force Special Operations Command sa cosa è andato male nell’incidente mortale del CV-22 e sta ancora indagando sul perché
L'Air Force Special Operations Command ha determinato quale parte ha fallito nell'incidente del CV-22 Osprey che ha ucciso otto aviatori nel mese di Novembre, ma sta ancora determinando il motivo per cui si è verificato quel guasto.
L'AFSOC ha annunciato l'aggiornamento del suo processo di revisione il 20 Febbraio dopo che NBC News aveva riferito che gli investigatori stavano esaminando la possibilità che un incidente con la scatola del rotore dell'elica avesse causato l'incidente mortale al largo delle coste del Giappone.
airandspaceforces.comAFSOC Knows What Failed in Deadly CV-22 Crash, Still Investigating Why
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 4 marzo 2024, 18:49
Il Pentagono revocherà il divieto di volo col quale ha messo a terra l'Osprey dopo l'incidente mortale occorso all'USAF in Giappone
Venerdì scorso funzionari statunitensi hanno detto all'Associated Press che, la settimana prossima, il Pentagono revocherà il divieto di volo col quale ha messo a terra il V-22 Osprey, questo a seguito di un incontro ad alto livello in cui il Segretario alla Difesa Lloyd Austin ha approvato i piani dei Servizi Militari per un ritorno sicuro e misurato alle operazioni.
apnews.comPentagon to lift ban on V-22 Osprey flights, 3 months after fatal crash in Japan
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 8 marzo 2024, 15:52
Nel momento in cui US Navy e USMC si accingono a riportare in volo i V-22 rimangono in sospeso alcune domande
news.usni.orgQuestions Remain as Navy and Marine Corps Prepare to Return V-22s to the Air
Se ne parla anche qui … airandspaceforces.comPentagon Clears V-22 to Start Flying Again After Three-Month Grounding
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 14 marzo 2024, 0:55
Il Ministero della Difesa giapponese ha affermato che i voli dei V-22 giapponesi potrebbero riprendere già Giovedì
Il Ministero della Difesa giapponese, in una dichiarazione rilasciata Mercoledì, ha affermato che i voli degli MV-22B Osprey statunitensi e giapponesi potrebbero riprendere già Giovedì.
L'annuncio fa seguito a un comunicato stampa congiunto di Venerdì del Ministero della Difesa giapponese (MoD) con le U.S. Forces Japan (USFJ) in seguito al fatto che il Naval Air Systems Command ha autorizzato l'Osprey a riprendere nuovamente le operazioni.
news.usni.orgJapanese V-22 Flights Could Start as Early as Thursday, Says MoD
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 9 aprile 2024, 19:12
Il primo CMV-22B dell'US Navy assegnato alla Costa Orientale è arrivato a Norfolk
theaviationist.comFirst East Coast-Assigned U.S. Navy CMV-22B Arrives In Norfolk
:usa2:
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 18 aprile 2024, 15:30
US Navy e USMC hanno ricominciato ad impiegare i V-22, al contrario dell'USAF che li sta ancora tenendo a terra
aviationweek.comU.S. Air Force Still Not Flying V-22s, But U.S. Navy, USMC Are
:usa
richelieu
Re: MV-22 Osprey
Messaggio da richelieu » 4 maggio 2024, 10:48
Il lento ritorno in servizio
airandspaceforces.comAir Force Slowly Returning V-22 Ospreys to Flight After Crash
