C-27J Spartan (e c-27A/g222)
richelieu
Re: C-27J Spartan (e c-27A/g222)
Messaggio da richelieu » 7 febbraio 2013, 14:51
Verso la fine i primi collaudi della "cannoniera volante" .....
Armed MC-27J on target for February firing trial .....
By: Luca Peruzzi (2 hours ago - February 7, 2013)
Source: Flight International
Alenia Aermacchi and ATK will complete the first phase of testing for an armed, multi-mission version of the C-27J battlefield airlifter by the end of February.
"The MC-27J version is not just a gunship", according to an Alenia Aermacchi source, "but an adaptable, agile and affordable platform solution to be equipped with a sensor, communication and weapon suite able to execute a wide range of customer-driven missions."
Unveiled as a product at the Farnborough air show in June 2012, the MC-27J is being developed and marketed by an Alenia and ATK team, with the companies acting as platform system integrator and modular mission and weapon system supplier, respectively.
"We are introducing roll-on and secure pallets, quick connect interface with avionics and aircraft systems, and working on an external antenna and sensor configuration to reduce operational limitations for transport missions," Alenia Aermacchi says.
The companies are offering a mission suite based on a roll-on/roll-off module, with two mission control operator stations, a cockpit display and command units capable of accomplishing a wide range of missions. The aircraft also boasts two electro-optical/infrared sensor (EO/IR) turrets for surveillance and weapon targeting, a new synthetic aperture radar, fire control system, secure radios and a datalink.
The armed configuration is based on a pallet-mounted ATK GAU-23 Bushmaster 30mm automatic cannon, also selected for the US Air Force's Lockheed Martin MC-130W Combat Spear special mission/gunship.
Weighing less than 900kg (1,980lb), with 500 rounds of ammunition, the weapon is fitted at the rear left door with the gun barrel protruding.
Flight International understands the gun has a slant range of 2.2nm (4km) from a 5,000ft (1,520m) altitude, and will be fired in unpressured conditions to enhance accuracy. The MC-27J also can carry precision-guided munitions, including those released from launchers incorporated with the aircraft's rear ramp.
An Alenia Aermacchi source says the first firing test phase will be performed at a US range, using a company-owned C-27J with a fixed gun with manual adjustment and cameras installed. The process will include five or six flights involving single and multiple rounds being fired, and will be completed during February.
The companies have, meanwhile, already started a second phase of work with an ATK-provided GAU-23 gun trainable mount, fire control software, installed EO/IR turrets and a mission system. These activities are scheduled to be completed, with additional testing, before the end of 2013.
Alenia Aermacchi says the C-27J has so far been ordered by 10 customers, with the latest being Australia and an undisclosed nation from central Africa. The company has so far delivered 54 of the 91 aircraft ordered, with more than 60,000 flight hours amassed and the type delivering an average availability rate of over 70%.
MatteF88
Messaggio da MatteF88 » 7 febbraio 2013, 14:56
Io voglio i brimstone o gli hellfire sotto l'ala però! :) :)
richelieu
Messaggio da richelieu » 7 febbraio 2013, 15:20
MatteF88 ha scritto:Io voglio i brimstone o gli hellfire sotto l'ala però! :) :)
E magari ..... un po' di napalm .....
:onfire:
sidew
Messaggio da sidew » 7 febbraio 2013, 17:27
richelieu ha scritto: un po' di napalm .....
Il napalm, lo senti? Non c'è niente al mondo che abbia questo odore.
Mi piace l'odore del napalm al mattino.
Una volta abbiamo bombardato una collina, per dodici ore, e finita l'azione siamo andati a vedere. Non c'era più neanche l'ombra di quegli sporchi ba**ardi.
Ma quell'odore... sai quell'odore di benzina? Tutto intorno. Profumava come... come di vittoria.
Un bel giorno questa guerra finirà.
Aldo
MatteF88
Messaggio da MatteF88 » 7 febbraio 2013, 17:39
Non è diventato illegale il napalm?
Però.... una cosa alla Harvest Hawk.. :roll:
MatteF88
Messaggio da MatteF88 » 7 febbraio 2013, 18:43
cioè così:
http://www.google.it/url?sa=i&source=im ... 5351550370
richelieu
Messaggio da richelieu » 8 febbraio 2013, 23:59
Draklor ha scritto:Brutte notizie per Alenia ...
http://www.xairforces.net/newsd.asp?newsid=2052&newst=3
E' da più di un mese che se ne parla ..... e poi ..... le Forze Aeree Afghane hanno ben poco da rallegrarsi della cancellazione del programma C-27A .....
Non c'è da meravigliarsi ..... quello dev'essere proprio un bell'ambiente .....
"As part of Washington's splurge on the Afghan air arm, two Afghan women were brought to the United States and trained as helicopter pilots (although one does not drive a car).
They returned home wearing pilot wings only to be ignored by the brass of their own air force and kept away from helo controls - because of their gender.
At press time, neither had made a single flight in an Afghan helicopter."
Fonte: Robert F. Dorr a pagina 11 del numero di Febbraio 2013 del mensile britannico "AIR International" .....
Messaggio da JT8D » 28 maggio 2013, 22:08
"La corsa di decollo è una metamorfosi, una quantità di metallo che si trasforma in aeroplano per mezzo dell'aria. Ogni corsa di decollo è la nascita di un aeroplano".
MatteF88
Messaggio da MatteF88 » 9 ottobre 2013, 15:47
E' iniziata la dismissione dei nuovi C-27J dell'ANG, gli esemplari già consegnati sono trasferiti a Davis Monthan per essere storati, gli esemplari ancora da consegnare verranno consegnati ma saranno portati direttamente nel deserto in Arizona..
http://www.dodbuzz.com/2013/10/07/time- ... -on-c-27j/
richelieu
Messaggio da richelieu » 25 novembre 2013, 18:19
Il Perù sì che se ne intende ..... :wink:
"Il Ministero della Difesa del Perù sceglie il velivolo da trasporto" .....
http://www.aleniaaermacchi.it/it-IT/Med ... C-27J.aspx
MatteF88
Messaggio da MatteF88 » 20 dicembre 2013, 14:07
il primo (di 10) destinato all'australia ha volato:
http://www.flightglobal.com/news/articl ... ne-394316/
richelieu
Messaggio da richelieu » 6 gennaio 2014, 18:29
Alla Guardia Costiera i 14 rimanenti C-27J ex-ANG .....
"US Coast Guard to acquire USAF's remaining C-27J Spartans" .....
..... http://www.flightglobal.com/news/articl ... ns-394575/ .....
"Coast Guard to Take Control of Last USAF C-27Js" .....
..... http://www.defensenews.com/article/2014 ... SAF-C-27Js .....
innox
Messaggio da innox » 7 gennaio 2014, 23:40
richelieu ha scritto:Alla Guardia Costiera i 14 rimanenti C-27J ex-ANG .....
Eh beh, la CG ha delle basi molto più interessanti...per fare l'Exchange Pilot!
8)
It's always better to be down here wishing you were up there than up there wishing you were down here.
richelieu
Messaggio da richelieu » 8 gennaio 2014, 9:48
innox ha scritto:Eh beh, la CG ha delle basi molto più interessanti...per fare l'Exchange Pilot!
8)
E che ..... sei già sul piede di partenza?
:wink:
innox
Messaggio da innox » 8 gennaio 2014, 11:03
8)
:wink:
Metto le mani avanti! E magari anche i piedi. :lol:
(ma ormai c'ho un' eta'…)
richelieu
Messaggio da richelieu » 14 febbraio 2014, 8:49
Il battibecco ..... Immagine
"Medium airlift and the big sales spat" ..... http://www.flightglobal.com/blogs/the-d ... ales-spat/
MatteF88
Messaggio da MatteF88 » 14 febbraio 2014, 10:47
Sullo sfondo...c'è sempre l'India... :?
richelieu
Messaggio da richelieu » 6 aprile 2014, 18:28
Alenia Aermacchi ha aperto un sito in lingua spagnola tutto dedicato allo Spartan .....
"Alenia Aermacchi: The C-27J Spartan Spanish Website is Live Online " .....
http://www.aleniaaermacchi.it/en-US/Med ... nline.aspx
Era ora che si decidessero ..... dal momento che il principale concorrente 'parla' proprio quella lingua .....
http://es.wikipedia.org/wiki/CASA_C-295
richelieu
Messaggio da richelieu » 9 aprile 2014, 10:37
Intanto ..... negli USA ..... l'ammiraglio comandante la Guardia Costiera esprime la propria soddisfazione per l'acquisizione dei 14 Spartan dismessi dall'USAF ..... =D>
"You Can't Beat Free" ..... http://www.airforcemag.com/DRArchive/Pa ... -Free.aspx
MatteF88
Messaggio da MatteF88 » 10 aprile 2014, 11:57
Se passate su fr24 ce n'è uno in volo vicino a Terracina ...MM62250 :mrgreen:
richelieu
Messaggio da richelieu » 10 aprile 2014, 14:41
MatteF88 ha scritto:Se passate su fr24 ce n'è uno in volo vicino a Terracina ... MM62250 :mrgreen:
Come lo preferisci .....
..... con i contrassegni della Quaranteseiesima AB .....
..... o con quelli del RSV ?
:wink:
MatteF88
Messaggio da MatteF88 » 10 aprile 2014, 18:34
RS, secondo me l'insegna è più bella :wink:
richelieu
Messaggio da richelieu » 12 aprile 2014, 20:53
In dettaglio ..... le dichiarazioni dell'ammiraglio Papp ..... comandante dell'USCG .....
"Coast Guard Commandant ‘Delighted’ to Get Air Force C-27s" .....
http://www.defense.gov/news/newsarticle.aspx?id=122026
spiridione
Messaggio da spiridione » 15 aprile 2014, 12:35
Da qualche ora un C27 (del quale non riesco a leggere le insegne) vola a bassa quota sulla Sardegna Meridionale. Ha già fatto tre/quattro low pass sul mio ufficio, a Villacidro.
C'è qualcosa che bolle in pentola (esercitazioni) ????? 8)
P.s. Quando dico low pass, intendo proprio low.....
richelieu
Messaggio da richelieu » 15 aprile 2014, 14:12
spiridione ha scritto: P.s. Quando dico low pass, intendo proprio low .....
Hai verificato l'integrità del tetto ?
:laughing3:
richelieu
Messaggio da richelieu » 15 aprile 2014, 20:40
In viaggio .....
"First Australian C-27J heads to USA" ..... http://www.aviationweek.com/Blogs.aspx? ... b2f5e1f827
spiridione
Messaggio da spiridione » 15 aprile 2014, 21:06
:laughing3:
No. Non sono problemi miei. Almeno non ancora....... :wink:
richelieu
Messaggio da richelieu » 30 aprile 2014, 14:49
MC-27J .....
..... se ne parla nel sito dell'AFA .....
"Dark Spartan's First Flight" ..... http://www.airforcemag.com/DRArchive/Pa ... light.aspx
Si vedano, all'interno, i links con Alenia e Jane's .....
richelieu
Messaggio da richelieu » 7 maggio 2014, 17:11
OT .....
Intanto ..... l'aereo della concorrenza (modificato all'uopo da ATK) è già stato consegnato al primo utilizzatore .....
"Jordan takes delivery of AC235 gunship" ..... http://www.flightglobal.com/news/articl ... ip-398981/
richelieu
Messaggio da richelieu » 8 maggio 2014, 9:50
Il Perù raddoppia ..... per ora .....
"Ancora Spartan per il Perù" .....
http://www.analisidifesa.it/2014/05/aln ... r-il-peru/
"I cargo italiani C-27J Spartan alla conquista del Sud America" .....
http://www.lastampa.it/2014/05/07/econo ... agina.html
" Il Perù compra altri due aerei Alenia. L'azienda: 'Assunzioni in Piemonte' " .....
http://torino.repubblica.it/cronaca/201 ... -85499599/
"El Ministro de Defensa de Perú visita en Italia la factoría de Alenia Aermacchi" .....
http://www.defensa.com/index.php?option ... Itemid=163
ghiga
Messaggio da ghiga » 8 maggio 2014, 14:57
E' una buona notizia per l'industria nazionale che il sud America guardi al C-27. Secondo me un velivolo molto valido, meno grande che un C-130,ma molto piu,' versatile.
richelieu
Messaggio da richelieu » 13 maggio 2014, 23:40
Il SOCOM e lo Spartan .....
"SOCOM progresses C-27J crew training ..... http://www.janes.com/article/37820/soco ... w-training
richelieu
Messaggio da richelieu » 22 maggio 2014, 23:56
Cannoniere volanti a confronto .....
After years in which aerial gunships were synonymous with the US-built AC-130, not one but two new offerings were on display last week in Jordan, reflecting a growing demand from other nations for aerial strikes by slow moving aircraft.
Fonte ..... "Two New Gunships Seek International Customers" .....
http://www.defensenews.com/article/2014 ... ionstories
richelieu
Messaggio da richelieu » 10 luglio 2014, 20:23
Dal sito del RIAT .....
The first aircraft to touch down at RAF Fairford was a C-27J Spartan airlifter arriving from the Baltic state of Lithuania.
This sizeable unit is always popular with the enthusiasts and puts on one of the most eagerly-anticipated displays as it performs the sort of manoeuvres - loops and rolls - more commonly associated with a fighter jet.
"First Arrivals Touch Down" ..... http://www.airtattoo.com/news/2014/jul/ ... touch-down
richelieu
Messaggio da richelieu » 23 luglio 2014, 17:49
Sostituzione, in India, dei vecchi bimotori Avro ..... sarà in corsa anche lo Spartan .....
"India advances Avro replacement programme" .....
http://www.flightglobal.com/news/articl ... me-401917/
