Spanish pilot killed in Eurofighter crash
http://www.flightglobal.com/news/articl ... sh-400225/
The pilot of a Spanish air force Eurofighter was killed when his combat aircraft crashed at Morón air base near Seville on 9 June.
Spain’s defence ministry named the deceased pilot as 30 year-old Capt Fernando Lluna Carrascosa, who it said had accumulated more than 600 flight hours’ experience on the Eurofighter. The cause of the accident – which happened as the aircraft was approaching the base to land – has not yet been determined, it says.
The destroyed aircraft was assigned to the 11th Wing at the base, which is home to the air force’s 111 and 113 squadrons. The service had an active fleet of 35 single-seat Eurofighters and 11 two-seat trainers prior to the mishap, as recorded by Flightglobal’s MiliCAS database.
The loss represents the second fatal accident to have occurred at or near the Morón base with a Eurofighter, after a Royal Saudi Air Force pilot was killed in a crash while training there in August 2010. These are the only deaths involving the type in around 240,000 flight hours amassed by 406 aircraft delivered to six air forces.
Re: Spanish pilot killed in Eurofighter crash
skype id: ladymachbet
http://www.giuda.it
http://www.giuda.it
- Mobius
Caspita...
Club Ulisse 2013 - Club Freccia Alata Plus 2014/2015 - Club Freccia Alata 2016
il testo dice che è il secondo Eurofighter a cadere sempre vicino a Moròn; il primo è stato della Royal Saudi Air Force, successo 4 anni fa, e questi due sono stati gli incidenti gravi occorsi a questo tipo di caccia.
dice che il pilota era della RSAF,hawk-eyed ha scritto:il testo dice che è il secondo Eurofighter a cadere sempre vicino a Moròn; il primo è stato della Royal Saudi Air Force, successo 4 anni fa, e questi due sono stati gli incidenti gravi occorsi a questo tipo di caccia.
la macchina era lo ST008 (Spanish Twin)
Non ho ben capito cosa e' successo..
Inevitabile chiedersi se la presenza dei due soli incidenti con perdita del mezzo all'EFA, nonché il terzo, in prossimità di quella base siano effetto di un banale cluster statistico o se vi sia qualcosa nel contesto planoaltimetrico o meteorologico o d'altra natura atti a favorire in certe circostanze particolari difficoltà a un pilota.
perdita del compressore del motore sinistro e perdita dell'autoritá di comando a cabraresigmet ha scritto:
Gli Spagnoli hanno gli EF schierati a Moron ed Albacete, nella seconda base solo dai primi mesi del 2013 e con solo 11 machine.....il problema é diverso ed anche gli spagnoli iniziano a chiedersi perche sono gli unici ad aver perso tre Tifoni.....Valerio Ricciardi ha scritto:Inevitabile chiedersi se la presenza dei due soli incidenti con perdita del mezzo all'EFA, nonché il terzo, in prossimità di quella base siano effetto di un banale cluster statistico o se vi sia qualcosa nel contesto planoaltimetrico o meteorologico o d'altra natura atti a favorire in certe circostanze particolari difficoltà a un pilota.
http://www.elconfidencialdigital.com/de ... 71292.html
