Mars Science Laboratory
Area dedicata alla discussione di argomenti relativi a volo spaziale, missioni spaziali, spacecraft, satelliti, astronautica
richelieu
Re: Mars Science Laboratory
Messaggio da richelieu » 7 ottobre 2012, 18:37
Sulla strada per "Glenelg" .....
View on the Way to 'Glenelg' .....
This 360-degree panorama from NASA's Mars rover Curiosity shows the rocky terrain surrounding it as of its 55th Martian day, or sol, of the mission (Oct. 1, 2012).
The base of Mount Sharp can be seen at upper left.
› Panoramic view ..... http://www.nasa.gov/images/content/6941 ... l_full.jpg
The sandy area seen to the right is a region called "Rocknest," which is the current candidate for Curiosity's first scooping experiments on Mars.
This image was taken by the rover's Navigation camera.
Image Credit: NASA/JPL-Caltech
richelieu
Messaggio da richelieu » 7 ottobre 2012, 18:45
"Rocknest" .....
'Rocknest' From Sol 52 Location .....
This patch of windblown sand and dust downhill from a cluster of dark rocks is the "Rocknest" site, which has been selected as the likely location for first use of the scoop on the arm of NASA's Mars rover Curiosity.
This view is a mosaic of images taken by the telephoto right-eye camera of the Mast Camera (Mastcam) during the 52nd Martian day, or sol, of the mission (Sept. 28, 2012), four sols before the rover arrived at Rocknest.
The Rocknest patch is about 8 feet by 16 feet (1.5 meters by 5 meters).
Scientists white-balanced the color in this view to show the Martian scene as it would appear under the lighting conditions we have on Earth, which helps in analyzing the terrain.
Credit: NASA/JPL-Caltech/MSSS
87Nemesis87
Messaggio da 87Nemesis87 » 10 novembre 2012, 11:04
perchè nella realtà marziana come si vedrebbe? tutto più rosa? :o
...finalmente laureato!!!
...ATPL: Completato!!
-- MEP, SEP, IR, CPL, MCC --
-- CRJ-100/900 Type Rated --
richelieu
Messaggio da richelieu » 27 novembre 2012, 14:45
Panorama .....
Panoramic View From 'Rocknest' Position of Curiosity Mars Rover .....
This panorama is a mosaic of images taken by the Mast Camera (Mastcam) on the NASA Mars rover Curiosity while the rover was working at a site called "Rocknest" in October and November 2012.
The center of the scene, looking eastward from Rocknest, includes the Point Lake area.
After the component images for this scene were taken, Curiosity drove 83 feet (25.3 meters) on Nov. 18 from Rocknest to Point Lake.
From Point Lake, the Mastcam is taking images for another detailed panoramic view of the area further east to help researchers identify candidate targets for the rover's first drilling into a rock.
The image has been white-balanced to show what the rocks and soils in it would look like if they were on Earth.
Image Credit: NASA/JPL-Caltech/Malin Space Science Systems
gattovolante
Messaggio da gattovolante » 28 novembre 2012, 16:26
"Forse Curiosity ha trovato su Marte semplici molecole organiche": lo ha detto Charles Elachi, direttore del Jet Propulsion Laboratory Nasa, a margine di un convegno all'Università Sapienza di Roma aggiungendo che "sono dati preliminari ancora da verificare, molecole organiche e non biologiche". Attesi dati il 3 dicembre a San Francisco.
La possibilità che sul Pianeta rosso siano state rinvenute tracce di vita c'è, ma a ridimensionare le attese ci pensa appunto Elachi. Ricordando che nelle ultime settimane si sono sono rincorse in maniera insistente voci relative a una scoperta di portata storica, il direttore del Jet Propulsion Laboratory Nasa infatti precisa: "Credo che i media abbiano esagerato nelle aspettative. I dati preliminari fanno supporre di aver identificato probabilmente semplici molecole organiche, non biologiche". Non c'è però nessuna sicurezza, visto che lo stesso Elachi aggiunge: "Purtroppo non ho avuto modo di parlare con i ricercatori in questi ultimi giorni in cui stanno elaborando le informazioni raccolte da Curiosity".
"Curiosit"! - ha spiegato ancora il direttore del Jpl - "non è dotato di strumenti per trovare tracce biologiche", ossia molecole necessarie o prodotte da forme di vita, "ma ha la capacità di riconoscere molecole organiche". La scoperta, se confermata, presenterebbe in ogni caso un dato molto importante in quanto le molecole organiche rappresentano i precursori necessari alla vita. I dati quindi lasciano aperte le porte alla possibilità che nel passato Marte abbia ospitato forme di vita ma non possono in nessun modo confermare questa tesi.
ANSA
richelieu
Messaggio da richelieu » 1 dicembre 2012, 16:38
Sarebbe stato bello ..... solo che ..... [-X
NASA Backs Off on Mars 'Historic Announcement' .....
An "historic" discovery made by NASA's Mars rover was teased by the space agency, but just when space enthusiasts were getting excited, NASA backpedaled, saying that the discovery won't be earthshaking, but it will be interesting. It may be a case of once bitten twice shy as NASA has been through this sort of "big discovery" before.
Fonte ..... http://www.sci-tech-today.com/news/NASA ... 0002VDRYP8
NASA denies rumours from Curiosity discovery .....
NASA is attempting to backtrack quickly after an earlier statement that the Mars Curiosity rover had recorded data from soil samples that were destined “for the history books.”
Initially, NASA spokesperson Guy Webster downplayed this suggestion and stated, “It won't be earthshaking but it will be interesting.”
Now NASA is saying, “Rumors and speculation that there are major new findings from the mission at this early stage are incorrect."
Fonte ..... http://www.clickonline.com/tech/nasa-de ... ery/15050/
gattovolante
Messaggio da gattovolante » 4 dicembre 2012, 0:21
...dai dai che li becchiamo prima o poi :alien: :alien: :alien:
"Gli strumenti del robot laboratorio "Curiosity" hanno scoperto tracce di molecole inorganiche, come composti a base di acqua, cloro e zolfo su Marte. Resta un alone di incertezza sulla possibile origine organica di molecole a base di carbonio e idrocarburi clorinati. Finora "non c'è certezza assoluta", ma continueremo a cercare in diversi ambienti del cratere Gale, ha dichiarato il responsabile del robot della Nasa, Paul Mahaffy"
Ansa
richelieu
Messaggio da richelieu » 4 dicembre 2012, 23:37
E già si pensa al futuro .....
NASA Announces Robust Multi-Year Mars Program; New Rover to Close Out Decade of New Missions .....
Building on the success of Curiosity's Red Planet landing, NASA has announced plans for a robust multi-year Mars program, including a new robotic science rover set to launch in 2020.
This announcement affirms the agency's commitment to a bold exploration program that meets our nation's scientific and human exploration objectives.
Fonte ..... NASA ..... http://www.nasa.gov/home/hqnews/2012/de ... _2020.html
richelieu
Messaggio da richelieu » 28 dicembre 2012, 9:03
Un nuovo autoritratto .....
Curiosity Self-Portrait, Wide View .....
On the 84th and 85th Martian days of the NASA Mars rover Curiosity's mission on Mars (Oct. 31 and Nov. 1, 2012), NASA's Curiosity rover used the Mars Hand Lens Imager (MAHLI) to capture dozens of high-resolution images to be combined into self-portrait images of the rover.
The mosaic shows the rover at "Rocknest," the spot in Gale Crater where the mission's first scoop sampling took place. Four scoop scars can be seen in the regolith in front of the rover. A fifth scoop was collected later.
Self-portraits like this one document the state of the rover and allow mission engineers to track changes over time, such as dust accumulation and wheel wear. Due to its location on the end of the robotic arm, only MAHLI (among the rover's 17 cameras) is able to image some parts of the craft, including the port-side wheels.
Image Credit: NASA/JPL-Caltech/MSSS
richelieu
Messaggio da richelieu » 10 febbraio 2013, 14:10
Dalla NASA .....
NASA Curiosity Rover Collects First Martian Bedrock Sample .....
NASA's Curiosity rover has, for the first time, used a drill carried at the end of its robotic arm to bore into a flat, veiny rock on Mars and collect a sample from its interior. This is the first time any robot has drilled into a rock to collect a sample on Mars.
L'intero comunicato ..... http://www.nasa.gov/mission_pages/msl/n ... 30209.html
richelieu
Messaggio da richelieu » 20 febbraio 2013, 23:58
Recentissime da Marte .....
NASA Rover Confirms First Drilled Mars Rock Sample .....
NASA's Mars rover Curiosity has relayed new images that confirm it has successfully obtained the first sample ever collected from the interior of a rock on another planet. No rover has ever drilled into a rock beyond Earth and collected a sample from its interior.
Link ..... http://www.nasa.gov/mission_pages/msl/n ... 0220b.html
richelieu
Messaggio da richelieu » 2 dicembre 2015, 14:16
Novità da Marte ..... :alien:
"Nasa, spunta una misteriosa cupola di metallo su Marte" .....
http://www.quotidiano.net/nasa-ufo-marte-1.1537332
"UFO Hunters Believe NASA's Opportunity Rover Has Found An Alien 'Dome' On Mars" .....
http://www.huffingtonpost.co.uk/2015/12 ... 86652.html
"Mystery DOME found on Mars: Alien hunters say structure was built by an ancient civilisation on the red planet" .....
http://www.dailymail.co.uk/sciencetech/ ... lanet.html
:scratch:
A meno che .....
..... non si tratti di ..... R2-D2 in trasferta su Marte per pubblicizzare l' imminente uscita di 'Episode VII' .....
Messaggio da JT8D » 16 giugno 2020, 20:43
A proposito di Marte e rover per il Pianeta Rosso:
https://www.md80.it/2020/06/16/airbus-s ... tch-rover/
"La corsa di decollo è una metamorfosi, una quantità di metallo che si trasforma in aeroplano per mezzo dell'aria. Ogni corsa di decollo è la nascita di un aeroplano".
richelieu
Messaggio da richelieu » 24 giugno 2020, 23:49
Questa, per Marte, sarà un'estate particolarmente 'calda' ...
... airspacemag.com ... https://www.airspacemag.com/space/armad ... 180974936/ ...
richelieu
Messaggio da richelieu » 2 agosto 2020, 9:35
Il rover "Mars 2020 Perseverance", superati i problemi iniziali, è felicemente in volo verso Marte ...
... nasa.gov ... "NASA, ULA Launch Mars 2020 Perseverance Rover Mission to Red Planet" ...
... blogs.nasa.gov ... "Mars 2020 Perseverance Exits Safe Mode, Successfully Heading to Mars" ...
richelieu
Messaggio da richelieu » 3 agosto 2020, 23:59
Alcuni articoli appena apparsi sul settimanale "The Space Review" riguardanti la missione "Mars 2020 Perseverance" ...
... "How the “Department of Exploration” supports Mars 2020 and more" ...
... "Propelling Perseverance: The legacy of Viking is helping NASA get to Mars" ...
... "Mars race rhetoric" ...
:usa2:
