Passaggio visibile sull'Italia della ISS
- Slowly
Segnaliamo il passaggio di stasera alle 21.30 circa sui cieli italiani della ISS che sarà ben visibile, tempo permettendo!
Qui maggiori dettagli
http://attivissimo.blogspot.com/2009/07 ... a-iss.html
- Slowly
Re: Passaggio visibile sull'Italia della ISS
- Slowly
Il lancio mi pare di capire sia stato rimandato per un controllo al velivolo in seguito ad un temporale.
- albert
Il lancio è stato rinviato a domani. L'area di lancio è stata colpita da 11 fulmini.Slowly ha scritto:Il lancio mi pare di capire sia stato rimandato per un controllo al velivolo in seguito ad un temporale.
Dal sito della NASA:
"Careful Testing Under Way After Lightning Strikes
Sat, 11 Jul 2009 05:59:52 PM UTC+0200
The launch of space shuttle Endeavour was postponed until Sunday evening so engineers could evaluate the spacecraft's myriad systems following 11 lightning strikes in the Launch Complex 39A area.
None of the strikes hit the shuttle or its external tank and solid rocket boosters, but there were strikes to the lightning mast and water tower. The launch pad is equipped with a lightning protection system of wires that is intended to steer bolts away from the shuttle.
"We've seen nothing so far that shows anything affected any of the systems," said Mike Moses, chairman of the pre-launch Mission Management Team.
Two of the strikes were strong enough to trigger an evaluation by engineers just to make sure all of Endeavour's systems are ready for flight. Although early evaluations showed no problems, engineers wanted more time to make sure they have checked everything correctly.
"We need to be 100 percent confident that we have a good system across the board," Moses said.
The launch time for Sunday is 7:13 p.m. EDT. The weather forecast calls for a 60 percent chance of acceptable conditions"
- Zapotec
- Astrid
Avvisatata
Ottico Abilitato. Specialista in Contattologia.
Appassionato di Medicina Aeronautica.
Pilota.
Pilota.
- albert
eh.. fortunello....Zapotec ha scritto:Vista !!
da me è stato sereno fino alle 20:00, poi il tempo ha deciso allegramente di rannuvolare, per un simpatico temporale che si sta preparando
- Zapotec
da me il tempo è stranamente NON afoso... altrimenti sarebbe stato sereno ma il cielo non si vede comunque... in compenso anche le zanzare mi hanno visto benealbert ha scritto:eh.. fortunello....Zapotec ha scritto:Vista !!![]()
da me è stato sereno fino alle 20:00, poi il tempo ha deciso allegramente di rannuvolare, per un simpatico temporale che si sta preparando![]()
ho chiamato anche moglie e figlia a vedere sto puntino che si muoveva, la figlia è rimasta stupuita (dopo che gli ho fatto vedere in grosso su internet cos'era quello che ha visto) che ci potesse essere un aggeggio così la sopra
ciao !
- Slowly
dovrebbe replicare poco dopo le 23
- Zapotec
sono ancora che mi metto il fargan per quella primaSlowly ha scritto:dovrebbe replicare poco dopo le 23
- DragonFly
- Slowly
In questi minuti è cominciato l'imbarco dei 7 memebri di equipaggio di STS127.
Al momento il lancio è confermato, il tempo pare tenere.
-4h
http://www.nasa.gov/mission_pages/shutt ... index.html
-4h
ieri sera l'ho vista bene nel cielo di milano!
- Slowly
Io mi guardando la diretta del lancio.
manca un'ora.
http://www.nasa.gov/multimedia/nasatv/index.html
manca un'ora.
- Astrid
Per che ora è previsto il lancio?
Pilota.
Pilota.
- albert
Lancio rinviato, a causa del maltempo, alle ore 18:51 EDT del 13.07, (00:51 del 14.07 in Italia)Astrid ha scritto:Per che ora è previsto il lancio?
ciao!
- Slowly
Dopo un raduno di MD80 ho fatto piovere sullo Shuttle...
Mi sa che Polanski mi sta cercando...
Speriamo stanotte sia la volta buona o si rimanda tutto di un mese, leggevo.
- geostazionario
Se si ha fortuna, ma capita raramente, si può vedere lo shuttle vicino alla stazione durante il docking/undocking.Slowly ha scritto:Segnaliamo il passaggio di stasera alle 21.30 circa sui cieli italiani della ISS che sarà ben visibile, tempo permettendo!
Mi è successo solo una volta ed è uno spettacolo pazzesco.
lrutragmi
lrutragmi
- Ashaman
Gli ultimi giorni... attualmente fino dalla metà di giugno, dalle mie parti è quasi sempre nuvoloso. Certo, fa la calura più sopportabile, ma anche il più potente dei binocoli/cannocchiali/telescopi (per non parlare della visione senza aiuti) serve a poco quando c'è una copertura variabile da 4/8 a 7/8.
Ultima modifica di Ashaman il 13 luglio 2009, 15:57, modificato 1 volta in totale.
-Benjamin Franklin
-Benjamin Franklin
- Fabri88
Cavoli me la sono persa.
Non ho mai visto l'ISS!
Ma quando la si vede (perchè mi pare che non è la prima volta che viene segnalata su questo forum) è visibile ad occhio nudo oppure bisogna avere strumenti ottici?
Inoltre, è possibile vedere la posizione della ISS da qualche parte su internet?
- Ashaman
Compra un binocolo da un cinese. 15 €uri (o anche meno se ci sai fare) e ti passa la paura. Ad occhio nudo magari trovi il punto da osservare, e poi tiri fuori il binocolo per migliore visione.Fabri88 ha scritto: Ma quando la si vede (perchè mi pare che non è la prima volta che viene segnalata su questo forum) è visibile ad occhio nudo oppure bisogna avere strumenti ottici?
-Benjamin Franklin
-Benjamin Franklin
- Fabri88
Ho un canocchiale con 60X di ingrandimento. Altro che Zhongguo!Ashaman ha scritto:Compra un binocolo da un cinese. 15 €uri (o anche meno se ci sai fare) e ti passa la paura. Ad occhio nudo magari trovi il punto da osservare, e poi tiri fuori il binocolo per migliore visione.Fabri88 ha scritto: Ma quando la si vede (perchè mi pare che non è la prima volta che viene segnalata su questo forum) è visibile ad occhio nudo oppure bisogna avere strumenti ottici?
- Fabri88
Per quanto riguarda la posizione ho trovato questo sito -----> http://www.amsat.org/amsat-new/tools/pr ... ellite=ISS
Dalla velocità in cui si muove dovrebbe fare il giro della terra in una mezzoretta.
Praticamente allora passa sopra quasi tutte le sere. O è un evento piuttosto raro (diciamo quell'1 o 2 volte all'anno)?
- Slowly
Bé non è che passa SEMPRE sulla stessa verticale immagino.Fabri88 ha scritto:Per quanto riguarda la posizione ho trovato questo sito -----> http://www.amsat.org/amsat-new/tools/pr ... ellite=ISS
In effetti come evento non è così raro, anche tra pochi giorni dovrebbe ripassare ed essere ancora più luminosa.
- geostazionario
Qui sotto il link che vi permette di sapere quando l'ISS e visibile dalla vostra città.
http://esa.heavens-above.com/esa/iss_step1.asp?nored=1
lrutragmi
lrutragmi
- Slowly
Endeavour ancora fermo per maltempo, si riprova, ora italiana, poco dopo la mezzanotte di domani notte.
- Slowly
- Slowly
Go to launch!
-10
-10
- albert
e... -8 lanci al grounding degli shuttle...Slowly ha scritto:Go to launch!
-10
- Zapotec
... e poi ?
- albert
L'Orion... utilizzando i vettori Ares I, nell'ambito del progetto Constellation.Zapotec ha scritto:... e poi ?
- Paolo_61
Trovi sul sito della Nasa l'illustrazione completa dei prossimi vettori utilizzati per l'esplorazione umana dello spazio.Zapotec ha scritto:... e poi ?
- neutrinomu
Giovedì nuovo spettacolare passaggio visibile in tutta italia (magnitudo -3.5 !)
Swishhhhh! Faster than light!
Gli orari indicati sono UTC? Ora locale italiana? GMT?
Grazie.
Grazie.
- neutrinomu
Ora italiana (cioè tra 45 minuti sirca). Per chi si perde lo spettacolo si replica sabato, stessa traiettoria a partire però dalle 20:55. Qui è possibile vedere real-time la posizione della ISS (ricaricare la pagina per agiornare)Whisky Charlie ha scritto:Gli orari indicati sono UTC? Ora locale italiana? GMT?
Grazie.
