Latest European F-16 crash
FAS
Messaggio da FAS »
This accident happened at Volkel Air Base in The Netherlands on September 22nd. The jet was an Dutch Air Force F-16B (a two seater). As they were taking off from a touch-and-go, a bird was sucked into the jet engine. The engine stalled, and the pilots tried to turn the jet around and get back on the ground, however, they lost control of the jet and ejected safely. Then, the abandoned jet veered towards the control tower and missed it by less than 3 meters. The plane hit the ground, then bounced over a Dutch Security vehicle and then crashed into a Protected Aircraft Shelter (PAS). The PAS has walls nearly 2 feet thick of reinforced concrete. That was fortunate, since there was another F-16 inside the PAS along with maintenance personnel. Luckily, no one was injured in this accident. Plane spotters near the end of the runway took the pictures of the pilots ejecting and the jet passing the control tower. The two pictures of the wreckage were released by the Royal Netherlands Air Force.
Staff: spostato in incidenti/inconvenienti
Ultima modifica di FAS il 9 novembre 2006, 13:47, modificato 1 volta in totale.
zksimo
Messaggio da zksimo »
2 (engines) is meglio che one,maxibon!!!!ma possibile che si deve buttare via un jet per un pennuto della miseria che vola in spazi aerei controllati senza xpdr mode C e 2 way radio comm?!
mcgyver79
Messaggio da mcgyver79 »
Non riesco a capire com'è possibile che l'F-16 sia solo un po' ammaccato dopo tutto 'sto casino... e soprattutto come ha fatto ad infilarsi in mezzo alle piante? :shock:
Ciaooooo.
McGyver
Snap-on
Messaggio da Snap-on »
Beh, direi che proprio ammaccato non è!
E' diventato un bel rottame! Non credo che ci possano recuperare molto!
saluti
Steve
mcgyver79
Snap-on ha scritto:Beh, direi che proprio ammaccato non è!
Per il tonfo che presumo possa aver fatto vederlo dritto e non in mille pezzi mi dà da pensare...
Ciaooooo.
McGyver
veltro15
Messaggio da veltro15 »
complimenti agli spotter per la foto dell' espulsione!
[hr]
Il pilota superiore:
quello che usa il suo giudizio superiore per non mettersi in situazioni che richiederebbero le sue abilità superiori per salvare il suo superiore cu*o!
veltro15
zksimo ha scritto:ma possibile che si deve buttare via un jet per un pennuto della miseria che vola in spazi aerei controllati senza xpdr mode C e 2 way radio comm?!
già, e fonti non ufficiali dicono che veniva pure da sinistra.... :lol:
[hr]
Messaggio da Maxx »
Una volta lessi di un pilota di F-A 18 che prese in pieno un cigno o un airone... insomma un volatile molto grosso, che gli frantumò il tettuccio e gli si infranse sulla tuta. Questo poveraccio (il pilota) dovette farsi non so quante ore di volo con lo stomaco, l'intestino e il cervello dell'airone o cigno sparsi per tutto il cockpit.
Messaggio da Maxx »
Ha mancato la torre per tre metri!!!! Vi immaginate che strizza?????
Er_Dete
Messaggio da Er_Dete »
Maxx ha scritto:Una volta lessi di un pilota di F-A 18 che prese in pieno un cigno o un airone... insomma un volatile molto grosso, che gli frantumò il tettuccio e gli si infranse sulla tuta. Questo poveraccio (il pilota) dovette farsi non so quante ore di volo con lo stomaco, l'intestino e il cervello dell'airone o cigno sparsi per tutto il cockpit.
ahò è successo paripari a un pilota di AMX, inondato di sangue!
Giogiò
Staff ItalianVipers.com
http://www.italianvipers.com
Messaggio da Maxx »
Che schifezza...
Blood
Messaggio da Blood »
Se ci fossero più bambole gonfiabili negli areoporti e sopratutto più hostess gli uccelli sarebbero più controllati...
[font=Comic Sans MS]In un Mondo regolato dalla legge causa/effetto ogni coincidenza è quanto meno sospetta N.W.[/font]
Staff
Andre
Messaggio da Andre »
Dio mio che immagini..... :shock:
Michele
Messaggio da Michele »
Blood ha scritto:Se ci fossero più bambole gonfiabili negli areoporti e sopratutto più hostess gli uccelli sarebbero più controllati...
hihhihihihi........e dove c'hanno il falco? :roll:
RMKS////
Er_Dete
andiamo nell'Hard :oops:
Giogiò
Ro60
Messaggio da Ro60 »
zksimo ha scritto:2 (engines) is meglio che one,maxibon!!!!ma possibile che si deve buttare via un jet per un pennuto della miseria che vola in spazi aerei controllati senza xpdr mode C e 2 way radio comm?!
Si potrebbero convincere gli animalisti ad installare un TCAS anche ai volatili... :lol:
Michele
:lol: ............
RMKS////
FAS
Messaggio da FAS »
Sul sito web milspotters.nl potete vedere piú foto dell´accaduto
