https://avherald.com/h?article=5345bfac&opt=0
https://www.aviation24.be/airlines/scan ... s-airport/
Incident: SAS A20N a Brussels 5 febbraio 2026 2026, tentato decollo dalla taxiway
- gabbiano
Re: Incident: SAS A20N a Brussels 5 febbraio 2026 2026, tentato decollo dalla taxiway
gabbiano ha scritto: 6 febbraio 2026, 13:20 https://avherald.com/h?article=5345bfac&opt=0
Incredibile..
- sardinian aviator
Domanda neanche tanto originale: Il CTA dove stava guardando?
Video esplicativo:
Non è la prima volta che qualcuno cerca di decollare dalla Taxiway, ma stavolta faccio proprio fatica a spiegarmelo !! E' andata bene che è riuscito a fermarsi poco prima della fine della Taxiway, nonostante era già sui 100 knots, secondo quanto riporta AvHerald.
Comunque mi associo alla domanda: ok l'errore dei Piloti, ma il controllore non si è accorto subito?
Sempre un piacere andarci…
AvHerald oggi riporta: "On Feb 13th 2026 the Belgian Air Accident Investigation Unit (AAIU) reported that after being cleared for takeoff from runway 07R the aircraft mistakenly lined up taxiway E1 at the intersection of taxiways Outer 10/C6, C5 and E1/Z and began a rolling takeoff. At the 100 KIAS call out the crew became aware of the misalignment. The aircraft reached 126 KIAS before brakes were applied and the thrust reversers deployed. The aircraft came to stop on the paved surface adjacent to the taxiway edges near the intersection of taxiways V1 and C1. There were no injuries, the aircraft did not sustain any damage. The occurrence was rated an incident and is being investigated by the Belgian AAIU".
(https://avherald.com/h?article=5345bfac&opt=0)
E' stato rilasciato il Preliminary Report:
https://mobilit.belgium.be/sites/defaul ... MINARY.pdf
