Boeing 777-236, LHR / EGLL investigation status
- FAS
dal sito web dell´Air Accidents Investigation Branch:http://www.aaib.dft.gov.uk/
Report iniziale AAIB Ref: EW/C2008/01/01
Accident
Aircraft Type and Registration: Boeing 777-236, G-YMMM
No & Type of Engines: 2 Rolls-Royce RB211 Trent 895-17 turbofan engines
Year of Manufacture: 2001
Date & Time: 17 January 2008 at 1243 hrs
Type of Flight: Commercial Air Transport (passenger)
Persons on Board: Crew - 16
Passengers - 136
Injuries: Crew - 4 (minor)
Passengers - 1 (serious)
Passengers - 8 (minor)
Nature of Damage: Substantial
Information Source: AAIB Field Investigation
Following an uneventful flight from Beijing, China, the aircraft was established on an ILS approach to Runway 27L at London Heathrow. Initially the approach progressed normally, with the Autopilot and Autothrottle engaged, until the aircraft was at a height of approximately 600 ft and 2 miles from touch down. The aircraft then descended rapidly and struck the ground, some 1,000 ft short of the paved runway surface, just inside the airfield boundary fence. The aircraft stopped on the very beginning of the paved surface of Runway 27L. During the short ground roll the right main landing gear separated from the wing and the left main landing gear was pushed up through the wing root. A significant amount of fuel leaked from the aircraft but there was no fire. An emergency evacuation via the slides was supervised by the cabin crew and all occupants left the aircraft, some receiving minor injuries.
The AAIB was notified of the accident within a few minutes and a team of Inspectors including engineers, pilots and a flight recorder specialist deployed to Heathrow. In accordance with the established international arrangements the National Transportation Safety Board (NTSB) of the USA, representing the State of Design and Manufacture of the aircraft, was informed of the event. The NTSB appointed an Accredited Representative to lead a team from the USA made up of investigators from the NTSB, the FAA and Boeing. A Boeing investigator already in the UK joined the investigation on the evening of the event, the remainder of the team arrived in the UK on Friday 18th January. Rolls-Royce, the engine manufacturer is also supporting the investigation, an investigator having joined the AAIB team.
Activity at the accident scene was coordinated with the Airport Fire and Rescue Service, the Police, the British Airports Authority and British Airways to ensure the recovery of all relevant evidence, to facilitate the removal of the aircraft and the reinstatement of airport operations.
The flight crew were interviewed on the evening of the event by an AAIB Operations Inspector and the Flight Data Recorder (FDR), Cockpit Voice Recorder (CVR) and Quick Access Recorder (QAR) were removed for replay. The CVR and FDR have been successfully downloaded at the AAIB laboratories at Farnborough and both records cover the critical final stages of the flight. The QAR was downloaded with the assistance of British Airways and the equipment manufacturer. All of the downloaded information is now the subject of detailed analysis.
Examination of the aircraft systems and engines is ongoing.
Initial indications from the interviews and Flight Recorder analyses show the flight and approach to have progressed normally until the aircraft was established on late finals for Runway 27L. At approximately 600 ft and 2 miles from touch down, the Autothrottle demanded an increase in thrust from the two engines but the engines did not respond. Following further demands for increased thrust from the Autothrottle, and subsequently the flight crew moving the throttle levers, the engines similarly failed to respond. The aircraft speed reduced and the aircraft descended onto the grass short of the paved runway surface.
The investigation is now focussed on more detailed analysis of the Flight Recorder information, collecting further recorded information from various system modules and examining the range of aircraft systems that could influence engine operation.
Accident
Passengers - 136
- Tixio
Re: Boeing 777-236, LHR / EGLL investigation status
Questo punto non mi è (del tutto) chiaro: per quale motivo l'autothrottle potrebbe aver richiesto quell'incremento di potenza? Niente di gestibile con un assetto diverso? Chiedo, naturalmente, agli ATP.FAS ha scritto:Following further demands for increased thrust from the Autothrottle, and subsequently the flight crew moving the throttle levers, the engines similarly failed to respond. The aircraft speed reduced and the aircraft descended onto the grass short of the paved runway surface.
Tixio®
Penso semplicemente per mantenere la velocita come fanno tutte le automanetteTixio ha scritto:Questo punto non mi è (del tutto) chiaro: per quale motivo l'autothrottle potrebbe aver richiesto quell'incremento di potenza? Niente di gestibile con un assetto diverso? Chiedo, naturalmente, agli ATP.FAS ha scritto:Following further demands for increased thrust from the Autothrottle, and subsequently the flight crew moving the throttle levers, the engines similarly failed to respond. The aircraft speed reduced and the aircraft descended onto the grass short of the paved runway surface.
- Tixio
Sì, beh...già...ma siccome in quella fase del volo non ci dovrebbe essere una richiesta di potenza tale da portare ad un simile risultato in caso di lack, chiedevo quali possono essere stati i motivi di una tale richiesta...i fattori causali, non quali scopi voleva raggiungere l'automanetta cercando più potenza...peterfly 65 ha scritto:Penso semplicemente per mantenere la velocita come fanno tutte le automanetteQuesto punto non mi è (del tutto) chiaro: per quale motivo l'autothrottle potrebbe aver richiesto quell'incremento di potenza? Niente di gestibile con un assetto diverso? Chiedo, naturalmente, agli ATP.
Tixio®
- francesco.mi
Il report è abbastanza vago, magari l'AT ha chiesto potenza perchè c'era già stato un calo di potenza e cercava di compensarlo?Tixio ha scritto:Sì, beh...già...ma siccome in quella fase del volo non ci dovrebbe essere una richiesta di potenza tale da portare ad un simile risultato in caso di lack, chiedevo quali possono essere stati i motivi di una tale richiesta...i fattori causali, non quali scopi voleva raggiungere l'automanetta cercando più potenza...
- Tixio
Perché un rapporto preliminare, non dà nessuna conclusione, ma solo le notizie di base dell'accaduto.alessandrogentili ha scritto: Il report è abbastanza vago,
Tixio®
- Michele
- Tixio
Sì, questo certamente. Il punto è: ha richiesto tanta potenza la cui mancanza ha determinato addirittura un atterraggio corto? In una fase del volo in cui la potenza necessaria è veramente pochina, poi....Michele ha scritto:Bè non mi pare così inusuale che AT richieda potenza anche in fase di atterraggio,con carrelli e flap estesi magari un po' di vento contrario,anche solo per dare una ''limatina'' alla velocità di atterraggio....
Penso al volo con un SEP: quella fase dell'atterraggio è sì un gioco di equilibri, ma non riesco (a parte una situazione eccezionale, tipo il windshear citato sopra e ipotizzato altrove) a trovare una particolare occasione in cui una lack di quella poca potenza necessaria mi determina un corto. Per questo chiedevo agli ATP: purtroppo un triplo7 non l'ho mai volato!
Tixio®
- Tiennetti
Stai facendo un avvicinamento e devi ridurre velocitá
Hai i motori in idle e tiri fuori la biancheria... in corto finale, con full flap e carrello la velocitá scende fino alla selezionata. Diciamo che in questa fase avrai bisogno di un 50% di N1.. é questo il momento in cui i motori non escono dall'idle (o aumentano poco) e l'aereo ha una resistenza brutale che portaa diminuire ancora di piú la tua velocitá
PEr fare un esempio... con l'MD80 se sei con i motori a IDLE e con un po' di FLAP con una VV minima hai un buon rateo di "frenata"
Con l'A/T inserita se non si portano almeno le manette al punto di LOW LIM il ritardo nella risposta sará tale che la tua velocitá scendera 10 o 15 nodi e ti manderá i motori a EPR LIM per poterla recuperare (con conseguente "calcio in c**o" dell'aereo... veramente poco confortevole)
- Tixio
Ok, ricevuto: è la risposta che aspettavo!Tiennetti ha scritto:Stai facendo un avvicinamento e devi ridurre velocitá
Di conseguenza un guasto importante alla gestione elettronica della propulsione ti mette non poco in difficoltà, mi par di capire...
Non voglio certo dire che sia quella la soluzione, ma è dall'inizio che ho l'impressione (e mi perdonerete che parli di impressioni qui, sottointendendo che con questo non voglio dimostrare NULLA) che la questione sia meno complicata di quello che sembra. Stiamo a vedere.
Tixio®
- Dany80
Si parla di una mancata risposta dei motori prima a un comando del Autothrottle e poi a un comando diretto dato dai piloti con le manette...Tixio ha scritto: Ok, ricevuto: è la risposta che aspettavo!![]()
In questo caso se il problema NON è nel motore e non è appunto nell'autothrottle in quanto provato comando anche con le manette dovrebbe appunto essere nella linea di gestione del motore e nei comandi.
Domanda interessante:
questo sistema è ridondante ? (suppongo di si)
e in che modo? (linea comando + linea backup, doppio comando con de linee che devono essere coerenti tra loro, altro?)
Può un sistema del genere non funzionare del tutto e quindi non trasmettere al motore la richiesta potenza fatta dalle manette?
Daniele
<br>
<br>
Da questi rapporti preliminari non si riesce a capire se al comando di throttle i motori si stavano spegnendo (o erano spenti) oppure se, anche se in funzione, non hanno effettuato la variazione di potenza richiesta dall'ap in corto finale.
Nel primo caso, la causa è unicamente da ricercarsi nel combustibile, è già praticamente impossibile una doppia piantata motore durante un volo, che poi si guastino due pompe fuel nello stesso tempo è oltre qualsiasi ragionevole valutazione.
Nel secondo caso, invece, bisogna capire se il problema è stato causato dalla parte avionica o dalla parte logica motore.
A quanto mi risulta i canali di comunicazione sono ridondanti, e in particolare due per ogni fadec, che si siano guastate quattro linee è assurdo, quindi converrebbe tenere fuori i motori per cause elettriche e tenerli in considerazione soltanto nel caso 1.
Mi chiedo, dal momento che non ho informazioni specifiche su queste macchine, il throttle passa in qualche modo sull'eicas?
Affermativo.Blackbirdsr71 ha scritto: Mi chiedo, dal momento che non ho informazioni specifiche su queste macchine, il throttle passa in qualche modo sull'eicas?
Aggiungo che i FADEC stessi sono ridondanti e, dopo aver analizzato i dati delle sonde nel motore, fanno feedback prima tra loro (quelli di ogni mototre) e poi tra un motore e l'altro.
- Tixio
Veramente dice chiaramente che è la seconda: l'AT ha chiesto potenza (ed in seguito l'hanno chiesta i piloti in manual) e l'impianto non ha risposto. I motori sembra ci fossero.Blackbirdsr71 ha scritto:Da questi rapporti preliminari non si riesce a capire se al comando di throttle i motori si stavano spegnendo (o erano spenti) oppure se, anche se in funzione, non hanno effettuato la variazione di potenza richiesta dall'ap in corto finale.
Tra l'altro non tornerebbero i conti con le testimonianze di alcuni passeggeri che hanno chiaramente asserito di udire il suono dei motori, e un "bang" non meglio identificato.
Tixio®
Il problema è che con i motori online non si spiega l'uscita della RAT durante il landing, evidenziata da alcune foto, a meno che una perdita completa di feedback (che è ancora del tutto ipotetica) si traduca in uno spegnimento motore da parte del fadec.Tixio ha scritto: Veramente dice chiaramente che è la seconda: l'AT ha chiesto potenza (ed in seguito l'hanno chiesta i piloti in manual) e l'impianto non ha risposto. I motori sembra ci fossero.
- Tixio
Attenzione, che la RAT fuoriuscita la si vede solo nelle foto dell'aereo già a terra, in volo (ci sono delle foto di FAS in giro) non si riesce a vedere.Blackbirdsr71 ha scritto: Il problema è che con i motori online non si spiega l'uscita della RAT durante il landing, evidenziata da alcune foto, a meno che una perdita completa di feedback (che è ancora del tutto ipotetica) si traduca in uno spegnimento motore da parte del fadec.
Ovviamente tutto ciò basandoci sulle foto, e su nient'altro. Dati certi non ne abbiamo....
Può essere poi che la RAT sia stata estratta (prendendo valida questa ipotesi) perché i piloti hanno supposto una perdita di energia ai comandi per spiegare la mancata risposta della manetta?
Tixio®
- francesco.mi
REPORT UPDATE
LINK http://www.aaib.dft.gov.uk/latest_news/ ... update.cfm
Accident to a Boeing 777-236, G-YMMM, on 17 January 2008 - Initial Report Update
Accident to a Boeing 777-236, G-YMMM, on 17 January 2008 at 1243 hrs
Initial Report Update 23 January 2008
Since the issue of the Air Accidents Investigation Branch (AAIB) 1st Preliminary Report on Friday 18 January 2008 at 1700 hrs, work has continued on all fronts to identify why neither engine responded to throttle lever inputs during the final approach. The 150 tonne aircraft was moved from the threshold of Runway 27L to an airport apron on Sunday evening, allowing the airport to return to normal operations.
The AAIB, sensitive to the needs of the industry including Boeing, Rolls Royce, British Airways and other Boeing 777 operators and crews, is issuing this update to provide such further factual information as is now available.
As previously reported, whilst the aircraft was stabilised on an ILS approach with the autopilot engaged, the autothrust system commanded an increase in thrust from both engines. The engines both initially responded but after about 3 seconds the thrust of the right engine reduced. Some eight seconds later the thrust reduced on the left engine to a similar level. The engines did not shut down and both engines continued to produce thrust at an engine speed above flight idle, but less than the commanded thrust.
Recorded data indicates that an adequate fuel quantity was on board the aircraft and that the autothrottle and engine control commands were performing as expected prior to, and after, the reduction in thrust.
All possible scenarios that could explain the thrust reduction and continued lack of response of the engines to throttle lever inputs are being examined, in close cooperation with Boeing, Rolls Royce and British Airways. This work includes a detailed analysis and examination of the complete fuel flow path from the aircraft tanks to the engine fuel nozzles.
Further factual information will be released as and when available.
Agli esperti i commenti....
- Tixio
Velocità sopra alla minima ma mancanza di comandi motore da un certo punto in poi, questo è il succo. A parte la novità dell'iniziale risposta, non cambia molto, in effetti...francesco.mi ha scritto: The engines both initially responded but after about 3 seconds the thrust of the right engine reduced. Some eight seconds later the thrust reduced on the left engine to a similar level. The engines did not shut down and both engines continued to produce thrust at an engine speed above flight idle, but less than the commanded thrust.
E questo è assodato, dunque...Recorded data indicates that an adequate fuel quantity was on board
Resta il fatto che:
Dovremmo dedurne (congettura) che stiano cercando soprattutto lì la chiave?This work includes a detailed analysis and examination of the complete fuel flow path from the aircraft tanks to the engine fuel nozzles.
Tixio®
Beh, il fatto che inizialmente abbiano risposto, e poi abbiano ridotto la potenza a distanza di 8 s uno dall'altro mi sembra significativo.Tixio ha scritto:
- Dany80
Pare quindi che:As previously reported, whilst the aircraft was stabilised on an ILS approach with the autopilot engaged, the autothrust system commanded an increase in thrust from both engines. The engines both initially responded but after about 3 seconds the thrust of the right engine reduced. Some eight seconds later the thrust reduced on the left engine to a similar level. The engines did not shut down and both engines continued to produce thrust at an engine speed above flight idle, but less than the commanded thrust
1) entrambi i motori erano accesi e probabilmente sono rimasti in IDLE fino all'impatto.
2) a una richiesta di aumento di potenza (necessaria dopo l'estensione flap e carrello) i motori hanno risposto ma successivamente (8 sec) il motore destro e poi quello sinistro sono scesi di potenza fino a "flight idle".
3) il carburante pare fosse sufficiente
Cosa diamine è successo quindi?
Daniele
<br>
<br>
- Tixio
N757GF ha scritto: Beh, il fatto che inizialmente abbiano risposto, e poi abbiano ridotto la potenza a distanza di 8 s uno dall'altro mi sembra significativo.
Tixio®
Secondo me il cambiamento e` drastico: se confermato, dal mio punto di vista professionale comincio a tirare un sospiro di sollievo (piccolo, in effetti ci sono ancora tante cose che possono essere andate storte).Tixio ha scritto: A parte la novità dell'iniziale risposta, non cambia molto, in effetti...
Se invece dici che non e` cambiato molto perche' l'aereo e` comunque atterrato corto, allora si`, non e` cambiato molto
Sei un aeronautico o un meccanico?
- Beorn
Se ho capito bene:francesco.mi ha scritto: the autothrottle and engine control commands were performing as expected prior to, and after, the reduction in thrust.
c'è stato un iniziale corretta risposta alla richiesta di potenza, dopo 3 secondi il motore di destra è sceso quasi a IDLE, seguito dopo circa altri 8 secondi (11 in tutto) dal motore di sinistra.
In tutto questo lasso di tempo e fino al contatto con il terreno, il sistema di controllo della spinta (fino a uno stadio che ancora non si conosce) ha funzionato corrrettamente, sembra quindi essere al momento escluso il blackout elettronico paventato inizialmente.
Esatto?
Gio'
Black, hai detto che i Fadec dei due motori si scambiano informazioni. Che genere di informazioni? O meglio, al motore 1 perchè dovrebbero servire le informazioni di funzionamento del motore 2 (e viceversa ovviamente) ?N757GF ha scritto:Beh, il fatto che inizialmente abbiano risposto, e poi abbiano ridotto la potenza a distanza di 8 s uno dall'altro mi sembra significativo.
quoti me per fare una domanda a blackalessandrogentili ha scritto: Black, hai detto che i Fadec dei due motori si scambiano informazioni. Che genere di informazioni? O meglio, al motore 1 perchè dovrebbero servire le informazioni di funzionamento del motore 2 (e viceversa ovviamente) ?
Si scambiano informazioni per controllarsi a vicenda, e se uno dei due sistemi di un motore va in avaria, quello dell'altro motore subentra e li controlla entrambi.
Se poi manca energia ai due fadec, l'aereo he` nei guai (capitato in un DA42
Esatto, ogni ECU del FADEC di ogni motore ha due canali contemporaneamente attivi, essi processano i segnali e ricevono in input gli stessi dati dai sensori nel motore. Uno rappresenta il canale attivo e fornisce i comandi in output, l'altro rimane in stand by, pronto a subentrare se necessario, e durante il funzionamento normale effettua una verifica incrociata sul canale attivo. Tra l'altro i due canali sono anche interconnessi via cross channel data link per scambiarsi i dati e rimanere operativi allo stesso modo se dovesse venire a mancare un input importante.
Questo all'interno di ogni motore.
Presumo, dalle parole di Black, che sul 777 anche l'ECU dell'altro motore effettui una verifica incrociata sull'altro.
Nel caso in oggetto, se non ricordo male, l'abbassamento di tensione che ha determinato lo spegnimento dei fadec è stato causato dal fatto che il diamond girava senza batteria (o era completamente scarica) e aveva avviato tutti e due i motori con la GPU.N757GF ha scritto:quoti me per fare una domanda a blackalessandrogentili ha scritto: Black, hai detto che i Fadec dei due motori si scambiano informazioni. Che genere di informazioni? O meglio, al motore 1 perchè dovrebbero servire le informazioni di funzionamento del motore 2 (e viceversa ovviamente) ?
Se poi manca energia ai due fadec, l'aereo he` nei guai (capitato in un DA42)
Ma l'impianto di quell'aereo è quanto di più diverso ci possa essere da un 777, dubito che il boeing in oggetto sia rimasto senza energia.
- Tixio
Non dico nulla, riportavo solo che tutto quello che ho scritto era A PRESCINDERE dal nuovo elemento, che, appunto, è l'unico elemento nuovo in più.N757GF ha scritto: Se invece dici che non e` cambiato molto perche' l'aereo e` comunque atterrato corto, allora si`, non e` cambiato molto![]()
Sul fatto che quell'elemento cambi qualcosa in particolare non so dire e infatti ho aspettato commenti più autorevoli del mio. Tu dici che cambia moltissimo, ma ancora non ci hai detto in cosa!
PS: sono aeronautico
Tixio®
Non ho quotato una frase a caso, penso anche io che sia significativo che entrambi abbiano avuto la stessa problematica a distanza di 8sec, e da qui mi sono collegato per la domanda a BlackN757GF ha scritto:quoti me per fare una domanda a black
Comunque grazie sia a te che a JT8D
Umh, non voglio togliere nulla agli ingegneri elettronici/informatici che hanno pensato a questa architettura, ma non era meglio due sistemi indipendenti ridondati al loro interno?N757GF ha scritto:Si scambiano informazioni per controllarsi a vicenda, e se uno dei due sistemi di un motore va in avaria, quello dell'altro motore subentra e li controlla entrambi.
Non penso che una "scatoletta Fadec" (il ferraccio per intenderci) costi molto, allora perchè non ridondare di più ogni singolo motore invece che ridondare sfruttando l'altro motore?
L'idea che mi è subito saltata in mente è che un fadec possa aver sbagliato e portato l'errore sull'altro (sto banalizzando per rendere l'idea).
(ovvio che queste sono tutte supposizioni MIE senza fondamento scientifico, se lo ritenete opportuno cancellatemi il post)
Mi sono spiegato male: ogni fadec e` doppio, due canali, ridondato per ogni motore, proprio come dici. Inoltre se entrambi i canali falliscono, si puo` usare il sistema dell'altro motore.alessandrogentili ha scritto: Umh, non voglio togliere nulla agli ingegneri elettronici/informatici che hanno pensato a questa architettura, ma non era meglio due sistemi indipendenti ridondati al loro interno?
No, era chiaro... Quello che io personalmente avrei evitato era l'uso del fadec dell'altro motore. Piuttosto avrei messo 3 fadec per motore.N757GF ha scritto:Mi sono spiegato male: ogni fadec e` doppio, due canali, ridondato per ogni motore, proprio come dici. Inoltre se entrambi i canali falliscono, si puo` usare il sistema dell'altro motore.
Mettiamola giù così, da sviluppatore software, avrei ragionato più a compartimenti stagni. Poi ripeto, è un mio parere personale...
