Volare a FL700
- sidew
Volare a FL700
su un Lockheed U2
Uno spettacolo vedere la curvatura terrestre all'orizonte ed il cielo gia nero...
- Mettiu
- ste1978
povvo
Re: Volare a FL700
- richelieu
Re: Volare a FL700
Molto bene .....
..... allora, cari amici, facciamogli gli auguri ..... perchè oggi è il suo 55° compleanno.
Ce lo ricorda Stephen Trimble nel suo blog "The DEW Line" di "flightglobal.com" .....
http://www.flightglobal.com/blogs/the-d ... y-u-2.html
..... e ..... come ha scritto "rapier" .....
..... Happy birthday, Old Warrior .....
Re: Volare a FL700
Ma nascerà un altro Kelly Johnson nel futuro della storia umana?
- richelieu
Re: Volare a FL700
Aspettiamo con fiducia .....AirGek ha scritto:..... Ma nascerà un altro Kelly Johnson nel futuro della storia umana? .....
- sidew
Re: Volare a FL700
Inoltre c'e un altra curiosita sugli u2, a quelle quote la velocita di stallo e appena inferiore di 10 nodi rispetto alla velocita max...
To maintain their operational ceiling of 70,000 feet (21,000 m), the U-2A and U-2C models (no longer in service) must fly very near their maximum speed. The aircraft's stall speed at that altitude is only 10 knots (19 km/h) less than its maximum speed. This narrow window was referred to by the pilots as the "coffin corner". For 90% of the time on a typical mission the U-2 was flying within only five knots above stall, which might cause a decrease in altitude likely to lead to detection, and additionally might overstress the lightly built airframe.
rif: Huntington, Tom. "U-2." Invention & Technology Magazine, Volume 22, Number 3.
- richelieu
Re: Volare a FL700
L'intero articolo di Tom Huntington .....The Coffin Corner
“[Maximum and minimum airspeeds] began to converge as you went higher and higher. It wasn’t too bad when you first leveled off, but as you continued through the flight and [went] higher, the indicated airspeeds would get lower and lower, and pretty soon you were down to, oh, maybe a 10-knot window in which you had to continue the rest of the flight. If you exceeded or bounced off the limits, either too fast or too slow, you got pretty much the same indication, so it was difficult to tell which you were encountering: approaching stall or approaching Mach limit.”
http://www.americanheritage.com/article ... 3_40.shtml
..... e la relativa "voce" di Wikipedia .....
http://en.wikipedia.org/wiki/Coffin_corner_(aviation)
- ste1978
Re: Volare a FL700
Vedendo l'atterraggio dell'aereo mi sto chiedendo come fanno a non farlo toccare con le ali per terra una volta che ha poca velocità o e fermo. Quando parte si vede che ha una specie di carrello che dopo perde prima del decollo e credo che poi le rimettono quando arriva ma come ?
- richelieu
Re: Volare a FL700
E chi gliele va a mettere le ruote mentre atterra? .....ste1978 ha scritto:..... Vedendo l'atterraggio dell'aereo mi sto chiedendo come fanno a non farlo toccare con le ali per terra una volta che ha poca velocità o e fermo. Quando parte si vede che ha una specie di carrello che dopo perde prima del decollo e credo che poi le rimettono quando arriva ma come ? .....
L'aereo viene "inseguito" sulla pista da un'autovettura, ovviamente ad alta velocità, a bordo della quale un altro pilota di U-2 fornisce al collega tutte le informazioni necessarie al compimento di un buon atterraggio.
L'aereo, alla fine della corsa, il più delle volte si appoggia dolcemente su una delle ali .....
In questo articolo, nella parte dedicata all'U-2, viene spiegata la procedura .....
http://www.aviationweek.com/aw/blogs/de ... d=blogDest
- ste1978
Re: Volare a FL700
ah ecco.. si le macchine (bei mezzi tra l'altro) le vedo sfrecciare dietro.. e in effetti nel filmato completo di James May on the moon viene detto che le auto aiutano l'atterraggio perchè è complicato con un aereo come questo.richelieu ha scritto:E chi gliele va a mettere le ruote mentre atterra? .....ste1978 ha scritto:..... Vedendo l'atterraggio dell'aereo mi sto chiedendo come fanno a non farlo toccare con le ali per terra una volta che ha poca velocità o e fermo. Quando parte si vede che ha una specie di carrello che dopo perde prima del decollo e credo che poi le rimettono quando arriva ma come ? .....![]()
Grazie per il chiarimento.
Re: Volare a FL700
Però dai, nel video una stecchetta l'ha data...
- richelieu
Re: Volare a FL700
Altri atterraggi .....
..... alcuni drammatici ..... al punto che alla fine il pilota viene ammanettato .....
- vihai
Re: Volare a FL700
State parlando del motoaliante?richelieu ha scritto: ..... alcuni drammatici ..... al punto che alla fine il pilota viene ammanettato .....
PizzOne
- richelieu
Re: Volare a FL700
L'U-2 è talmente "usa e getta" che è praticamente uno degli aerei più longevi attualmente in servizio .....PizzOne ha scritto:..... Ma sono aerei usa e getta?.....
Re: Volare a FL700
Vedere l'aereo che va fuori pista e la macchinina che lo insegue è fantastico. Mi sembra di vedere il papà che insegna al figlio ad andare in bici e ad un certo punto il figlioletto inizia a traballare, quindi il papà che magari era rimasto un pò dietro si mette a correre per riprenderlo.
Fantastico
Fantastico
- Mettiu
Re: Volare a FL700
aggiungo anche questo..
http://www.youtube.com/watch?v=I_3WeYXD ... re=related
e il link della storia dell'unico atterraggio dell'u-2 su una portaerei
http://www.aerospaceweb.org/question/hi ... 0050.shtml
- Superkick
Re: Volare a FL700
Spettacolare...
non si può non amare l'aviazione. Cosa altro ti da la possibilità di vedere la terra da dove fino a un secolo fa persino i più ricchi e potenti sognavano?
VENDO JOYSTICK SAITEK X52 PRO
***Il mio Tour Mondiale su IVAO***
Ministro della Stampa - Birra Point
- Aldus
Re: Volare a FL700
Che tosto sto aereo.
Praticamente un aliante a reazione.
Avete visto cosa segna la strumentazione a fl700, soprattutto l'anemometro?
Mach 0.7 per solo 104 nodi.
Non solo, notate come a 110 nodi c'è la banda rossa dell'overspeed, e a 100 nodi c'è quella di stallo.
10 nodi di margine tra il "troppo troppo" e il "troppo niente".
Bestiale.
Bestiale.
- Superkick
Re: Volare a FL700
Uno stallo a 70.000 piedi...Aldus ha scritto:Che tosto sto aereo.
Mach 0.7 per solo 104 nodi.![]()
Bestiale.
- Almost Blue
Re: Volare a FL700
Ma che gli schermi di presentazione cambiano configurazione a seconda della quota?
A 02:22: 29270 piedi per 153 nodi (di velocità indicata?). Io non vedo nè i segni dello stallo, nè dell'overspeed.
Invece a 05:27 è diverso. 70000 piedi per 104 nodi. Mach 0.7 (velocità al suolo?) e si vedono le tacche dello stallo a 100 nodi e dell'overspeed su tutti e due gli strumenti a destra e sinistra.
Su Wikipedia dice che la velocità di crocera dell'U-2 si aggirerebbe sui 373 nodi (ma di QUALE velocità?).
- sidew
Re: Volare a FL700
Gia, come dicevamo qualche post fa, questo e' il "Coffin Corner"...Aldus ha scritto: Mach 0.7 per solo 104 nodi.![]()
Bestiale.
Re: Volare a FL700
Oltre una certa quota si sale a numero di Mach costante, il che causa una riduzione della TAS e una ancor maggiore riduzione di CAS.Almost Blue ha scritto:Ma che gli schermi di presentazione cambiano configurazione a seconda della quota?
Quindi a 29K ft 153kts di CAS, saliamo a Mach costante, la TAS si riduce e arriviamo a 104kts di CAS.
373kts è senz'altro la TAS che a densità minori del valore ISA al MSL è sempre maggiore della CAS.
A 70K ft la densità dell'aria è bassissima, quindi come vedi la TAS è maggiore di 269kts rispetto alla CAS.
- Aldus
Re: Volare a FL700
Infatti.Superkick ha scritto: Uno stallo a 70.000 piedi...anche ammesso che si può recuperare (non lo so), ma come fai a recuperarlo con quei margini di velocità? Rischi di andare subito in overspeed, e di brutto.
Con l'U2 la parola d'ordine è "non sbagliare mai".
Non c'è margine per l'errore, l'errore con questo aereo non è contemplato.
Solo pochi e validi piloti erano abilitati al pilotaggio dell'U2, non era certo un aereo per tutti, e aveva una struttura anche delicata tra virgolette (avevo letto da qualche parte che se superava l'overspeed perdeva subito le ali).
E pensa che l'altro suo "simile, l'SR-71, andava ancora più in alto, ben 85.000 piedi, dico 85.000!
Praticamente era uno Shuttle che "volava basso".
Se l'U-2 per certi versi è stato un aereo straordinario, l'SR-71 è stato veramente il massimo dell'inimmaginabile, soprattutto considerando il periodo (anni 60), e considerando che non era un missile con propulsione a razzo (ma filava come un razzo, mazza se filava!!)... insomma era un aereo, un normalissimo aereo (normalissimo per modo di dire).
Cosa ci si inventava eh per andare a spiare il nemico?
- Aldus
Re: Volare a FL700
Porca miseria.richelieu ha scritto:Altri atterraggi .....
E pensare che quei piloti sono i migliori, i più qualificati, insomma quelli con le palle quadre abilitati per questa macchina.
Vaderli fare tutte quelle peripezie in atterraggio credo dia un quadro abbastanza chiaro della difficoltà di pilotaggio di questa macchina.
Non deve essere uno scherzo decollare e atterrare con un U-2.
Tuttavia viene da chiedersi un ovvia domanda: "Caro Kelly, ma ti ci voleva tanto progettare un qualche sistemino che permettesse al tuo gioiello di atterrare in grazia di Dio?"
Non per altro, ma ve la immaginate la fatica (e i rischi) nel fare una missione di spionaggio fotografico su un territorio nemico, e poi rischiare di perdere tutto sul proprio territorio, a casa propria, a causa delle bizzarrie in atterraggio dell'U2 che potrebbero distruggere l'aereo o incendiarlo?
Eddai mister Kelly, uno sforzino in più si poteva fare, o no?
- Almost Blue
Re: Volare a FL700
Atterrare con un aereo che è un aliante a carrello unico centrale mica devìessere tanto facile.
Nel primo video il pilota tocca prima con il ruotino di coda, POI mette giù quello principale. Inoltre mi sa che a muso su davanti non si vede niente, da qui la macchina con un altro pilota che gli va dietro.
- richelieu
Re: Volare a FL700
Aldus .....
..... E pensare che quei piloti sono i migliori, i più qualificati, insomma quelli con le palle quadre abilitati per questa macchina .....
E infatti sembra che Powers fosse proprio il migliore e per questo venne scelto per compiere quella missione, che sarebbe riduttivo definire impegnativa, che prevedeva l'attraversamento da sud a nord dell'intera Unione Sovietica .....
..... e che, quasi, gli risultò fatale .....
